Hello,
I have just added a JTech Photonics laser to my SPXXL.
Using Lightburn and I want to home the machine without moving the Z Axis.
Can this be done?
Hello,
Can this be done?
GRBL cannot home without moving the Z axis.
Ahhh Man?
So one cannot edit GRBL to ignor Z movement? So I have to reset Laser focus each and every time?
BUMMER!
Homing behavior is compiled into GRBL, it’s not a runtime setting.
Is there a way to automate focusing a laser?
Can a custom Z-probe be used?
I’ve never used one, but it should be like setting a zero.
I just thought of the answer. Lightburn does not have a probe option.
Thanks Rob! If I’d given it more thought I’d have known the answer.
After your figure out your focus position in Z after homing you could use quick actions to move to that Z position. After getting to the Z position you want you could go into the laser mode with your software like LightBurn or other.
Is there a gcode/mcode command for flipping a “homed?” flag to true?
Obviously this would come with multiple caveats, but it could avoid or minimize movement along the z axis.
I might recommend you make a simple spacer tool based on the focal distance to set your Z height.
Universal Laser uses this sort of tool and process: link
I have one. Once I set it I prefer it not move.
