Hi i’m new to the Shapeoko pro and having problems with Z. I know there’s a ton of stuff out there regarding this topic but unfortunately it hasn’t helped. I will outline my process and hopefully you can figure out what I’m doing wrong.
OK we’ll get started with Carbide Create Pro Settings for thickness, Z=9.525 mm. I will attach the file.
And now for the Shapeoko Pro.
I parked the machine turned it off/on. Loaded carbine motion connected to cutter.
At this point
Position
X =380.175
Y = 383.825
Z = -15. 410
Machine
X = 0
Y = 0
Z = 0
Load new file
Program size
X = 90.00 mm
Y = 163.00 mm
Z = 11.51 mm
Cutting depth below program zero -8.51MM
Initialize
Quick action to move cutter above current XY Z
Position.
X = 0
Y = 0
Z = 56.870
Machine.
X = -380.175
Y = -383.825
Z = -3.000
Jog
Position Z above Stock
Zero Z
Position.
X = 0
Y = 0
Z = 0
Machine.
X = -380.175
Y = -383.825
Z = -59.125
Run start job
X Y & Z same as above
Job just runs and never cuts into what wood.
Thanks John
Tools.c2d (916 KB)
