How do I add more text fonts to CC
I want to add to the library of text fonts in Carbide Create, hoe would I do that?
Check this post out for your answer.
What @Zman said, but be aware that if you use two computers with your machine, e.g. one to produce the design and another to run the machine from, it would be prudent to install the fonts (and Carbide Create) on both machines, just in case you want to make minor adjustments to the design file on the second machine. Otherwise, it will look different in Carbide Create. It doesn’t matter for Carbide Motion though, because that does what it’s told.
thank you, it worked perfectly
