First, I’ve read the Shapeoko CNC A to Z (toolpaths, feeds & speeds, etc.) and I’m still not sure I understand. Also, I can’t figure out “finishing passes”, if that’s the answer.
Question: How to I make these cuts better? I’m doing an insane amount of sanding and cutting with razor blades and it still doesn’t look good. I’d rather the CNC cut for an extra hour to clean things up than me spend two hours manually trying and failing.
This was a good, solid, flat piece of wood (Poplar or Knotty Pine, don’t remember).
