How do i generate gcode with Carbide Create?
Thanks for the reply
I am a novice What is CM566 and how do i use it?
That is Carbide Motion build 566. I know, citing Version numbers then seeing Build numbers is quite confusing, at least to meā¦
Seems like the āversion numberā should in the āaboutā window along with the build number. Or am I missing something???
What machine do you have? and what version of Carbide create are you using, the free version, or the Pro version?
@stanmckinnon Carbide isnāt using the traditional version control schema (at least not externally - I have no insight to their internal version control). Every change is a version number change and builds are hidden entirely.
In most software parlances that Iāve been involved with, CM566 would be CM ver 5 - which represents a family of function a MAJOR release level. .66, where the ā.ā dot represents a minor-version number - representing new functionality, but not enough to warrant a new Major version number. Then, there could be different build numbers within 5.66 for different operating systems, different hardware (if they differed by hardware), etc. but functionally, all of those builds would be identical to any other build of 5.66. Carbide calls the release 566 and does not show the differentiation with different operating systems.
I donāt know what they would do if they had 100 minor releases to a version!
Thanks for your reply
I have loaded CM566 and are convinced that it is not what i need for my application. CM566 is as stated is a āMotionā controller similar to the Mach3 controller that l am now using. I did not see anything in there to
generate gcode to send to the controller. I am looking for software to
read the toolpaths in Carbide Create and generate gcodes for Mach3.
Please correct me if l are on the wrong path
Itās hard to help when you donāt answer the questions asked of you.
So, reading between the lines, you are not using a Carbide 3D machine, and are trying to generate Gcode for it with the free version of Carbide Create. The free version does not directly output gcode, the pro version, from what I understand, can output gcode without having to be sent to another application, or to Carbide Motion.
