I am trying to figure out how to use carbide create to drill holes. My stock is 12.75 x 7.75. I want to drill 1/8 holes every inch. This is my first time trying to figure this out with no luck.
Put circles w/ their centers where you want to drill at.
Use the Linear array command if desired to create multiples on 1" spacing.
Then assign a Drill toolpath w/ appropriate setting to the desired depth.
Does it matter the size of the circle?
No, but I like to make it the size of the expected hole.
Ok I have all the circles. How do I reduce them to 1/8 ? On my design page the radius is 0.4631. How do I change it to 0.1250? Or should I just leave that?
I believe I figured it out. Scaled it down to the size I need
Thank you for your help
When you select a circle, a field should appear on the left to enter the radius. 0.125 diameter is 0.0625 radius ![]()
What @Tod1d said works for a single circle. I dont think you can reduce all the circles at once. So maybe delete all of them and start over with the array command with the proper size circle.
Thank you. I actually did what you suggested. I deleted and made one the size i needed and duplicated it.
