Any help with this? I am trying to carve a text with a .125 ball and cannot tell carbide create how deep I want the overall lettering to be. Is there a way to change that?
Mike,
Do you really want to do a V-carve with a ball endmill ? 99.9% of the time you will want to use a V-bit.
Anyhow, when vcarving the depth is set by the width of features inside which you carve, so you cannot set it yourself. In some CAM programs you can set a limit depth for vcarving toolpaths, but not in Carbide Create.
I thin k that there is a terminology issue here, if you want to carve a line with a ball end, you would use a contour toolpath, for VCarcing you would use a Vbit. The Vbit will try to “join” both sides of the vector forming a letter.
Julien,
Thanks for your response. What would you suggest I do to carve a text?
I understand that part. When I go to toolpath and create using contour option and then choose pocket, nothing happens. But when I choose vcarve, I can then carve text.
check this out, use it for letters
Contour and pocket are two different toolpaths. The contour will follow a line with the bit (inside, outside or on the line) while a pocket will cut everything between the lines. Of course for a pocket, you need to have the room for the bit to pass in between and a closed vector. For example, a pocket would not work when there are two parallel lines or if the space is too small for the bit to pass between the lines of a closed vector.
how do i set the parameters for an amana tool in carbide create? if i can’t do that, is there another software i need to download?
See here
Thanks for your help
To elaborate, for V carving in Carbide Create (and most programs) you can go deeper by using a V endmill with a sharper taper angle.
Guidelines for how taper angle should relate to feature size at: https://wiki.shapeoko.com/index.php/Endmills#V-bits
While Carbide Create doesn’t support doing a V carving with a ball-nosed endmill, the opensource program F-Engrave from Scorchworks does.
I manually lower the v-bit about a 1/6th after zero when I know it will not cut deep enough.
Thanks guys, I was just going to ask the same question after using my V bit today
If anyone does this,just make sure that your safe Z height is high enough to provide adequate clerance,especially if you workpiece is not flat.
