What’s going on when Carbide Motion uses the BitSetter? The log feature in Carbide Motion does not show everything, so rigged up a connection via an RS-232 level shifter to the serial port header on the controller board that would allow me to monitor the serial communication between the ATmega16U2 and the ATmega328P.
I can see that it does a G38.2 to to probe the button on the bitsetter, then I had assumed it was using a G10 or G92, but I don’t see that. I don’t see it doing anything to adjust the tool offset or coordinate offset.
Is Carbide Motion doing tool offsets entirely in software?
But seriously, I know enough to leave you confused.
CM switches to a different coordinate system to locate the bitsetter button height, then uses the difference of that other coordinate system to detect the difference in bit heights.
But it doesn’t update or switch coordinate systems using any G-code commands. During a tool change, all I see are G38.2, G0 and G4 I only captured during the initialization/jog/toolchange phase. I guess I should capture more data to see what it does when actually cutting.
Here’s what I see being run during a tool change:
G0X-2.5000Y-850.0000Z-5.0000 (rapid to BitSetter button)
G0Z-15.0000 (rapid down a bit)
G38.2Z-155.0000F800.0 (quick probe )
G4P0.005 (pause on button)
G0Z-66.6650 (short retract to release button)
G38.2Z-216.6650F50.0 (slow probe)
G0Z-5.0000 (retract)
G4P0.005 (pause)
G0X-434.5000 (return to front center)
G4P0.005 (pause)
I can’t decide if that is a really good idea, or a really bad idea. I guess it’s safer in that CM doesn’t need to worry about the state of the GRBL, as it’s always in machine coordinate space. Now I understand what the “To send directly to GRBL, begin line with /” text means in the MDI dialog box. Without the slash, CM is translating coordinates on the fly.
