How long can you let a Pro 5 sit idle?
I just made the first McEtcher cut on Acrylic and painted it with acrylic paint.
I have learned you can let the paint dry and then rub of the excess. The non-machined surface clears off relatively easily.
A Contour path with a 501 engraving bit is next. That will be painted a different color.
I am wondering a how long people let a Pro 5 sit without movement .
My ambient temperature is 65 deg F .
The steppers are 77 deg F and the controller is 102 deg F.
I have had loss of origin ( a couple of thousands ) before, so I want keep the machine on for a couple of hours.
Any thoughts or checks I should think about ?
At idle with the power on is the maximum stress on a stepper motor. That said letting your machine idle for a few hours will not hurt anything. You just dont want to leave a Shapeoko on all the time.
Ok. I will go with that.
The components temperature never went up past the original numbers.
