The specs say the spindle motor is 130W, but how many watts does the whole machine require? I just need a ball park figure.
Thank you.
Thank you.
Please check your power brick — it should note on the label what sort of current it can output — that should allow calculating Watts.
Thank you for your reply. I don’t currently own one. I am strongly considering it though.
I found the answer. Thank you.
“I found the answer. Thank you.”
…and the answer is?
Well, I found out it has a 3.5 A power source so
3.5 A x 110 V = 385 Watts
