How tight to have belts
Hi,
In addition to the insanely annoying jobs being interrupted half way issue, I’m also getting distorted shapes…
I guess my belts are too loose, how tight is too tight? I’m struggling to get the x axis tight??? is it worth trying to use longer bolts to pull the clamps in from further away?
thanks
Rob
Please see:
I find it easiest to do something of a round-robin:
  • initially tension belt with gantry in in middle
  • move to one end, re-tighten that end
  • move to other end, re-tighten there
  • move gantry to center and check belt tension
Like most things, a bit of practice/repetition will increase one’s facility with it.
thanks, i’ll keep at it!
also make sure the “sprocket” is solidly connected to the motor axis; if there is slip there is will LOOK like belt slip in many ways
there’s a little M3 thiny to hold these tight; after a crash (my own fault) I’ve had to tighten those
