I need to create a hinge for a wooden box. The plan is to later drill a hole through the fingers here and capture a dowel between the outside ends.
In my beta test, I used a drilling operation first to drill out the circles, then just did a contour to cut out the rest of the shape. Not a good idea, as it burned the wood. I guess ideally, I would just overrun the toolpath in the corners, but not sure how to do that.
If you add a square vector, you have the option of setting the type of corners, and dogbone is an option use a radius half the size of your bit diameter.
