I did a search but didn’t find any info. Just general advice.
I’d like to make a tray out of 6 x 6 1" cast acrylic
I have the #201 set, 10 minutes for a 4x5 pocket, not too bad but rather use the bowl and tray bit for a nice bottom corner radius but I don’t see it on the list.
Once cut you have tool marks correct? Which will clean up clear with buffing.
I recall a trick from my sign days you could take a torch to the edges of cut sheets to polish them clear. Anyone ever try that?
My ulterior motive is to make a Dan Armstrong body down the line when I’m confident I can cut a slab that big and expensive.
Thanks
