How to fill a field with hexagons using Carbide Create
as requested on support…
… insert a pattern (ie hexagon or honeycomb pattern) into a template?
Carbide Create does not have an automatic facility for that — here’s how to do it manually…
First, select the geometry which one wishes to fill:
Then draw in a hexagon:
Then position it so that the design will be encompassed by the hexagon:
and use the Linear Array tool to make a column of them:
OK
copy-paste the stack:
and drag the duplicate into alignment with the first:
Then, select all the hexagons and repeat, doubling their number:
repeating until the field is full:
Select the region which is being used, and duplicate it in place by copy-pasting with the cursor outside the drawin area:
Then add an alternating selection of hexagons to the selection:
and use the Trim Vectors tool:
to allow one to delete what is not encompassed by a selected hexagon along the perimeter:
until one arrives at…
OK
OK
Join Vectors:
Yes
Repeat until one arrives at:
Delete the unnecessary geometry:
Attached as v7 file.
Utah_beehive_v7.c2d (92 KB)
