How to flatten an endgrain cutting board on the CNC
Hello Andrew,
The bit left brown (not black) burn marks all the way. Since I lowered the speed of rotation and doubled the feed rate, I no longer have traces and the surface is perfect. A light sanding 180/240 gives a well finished surface.
JL
What did you set the speed and feed rate to? Just curious because I’m getting the brown marks too!
I applied the recommandation I got from Martin above…
RPM 18000 (position 4 on the Makita router) and I override the feed rate to 200%
I works well on endgrain and its a joke on medium
JL
Thank you! I missed his comment. 200%! Wow! I had mine at 100%.
