Clicking the Pause button in Carbide Motion during operation causes the bit to move upward above the stock. This is great.
I am using Fusion 360 and, after contouring a center piece (without tabs), I want to generate a pause in the gcode so that I can manually lift out the now floating center piece.
Fusion 360 has a Manual NC command that allows me to generate a Force Tool Change command (which works) but I don’t know how to generate a pause.
What G code is generated to cause the pause?
Here are the Fusion 360 options.
Any ideas?
thanks,
Richard
