How to go to predetermined origin
I have set up a jig and want the router to go to a specific location for repeatable cuts after the project is moved and returned for further CNC work. I am sure someone has figured this out. My steps so far:
Initialize machine, run MDI $H/ (home machine). Zero X and Y. The then run the following gcode: /g53 g20 x-32.441 y-11.235 This gets me to the location I want. I then zero X and Y. If I hit the Z- or Z+ in Carbide Motion from the computer or Sony Gamepad, The cutter has a mind of its own and goes all over the place.
I am new to this, if anyone has a solution I would greatly appreciate assistance. Thanks, Joe
Rather than use a workspace coordinate system, my solution on this sort of thing is just to use one of the rapid position points as the origin for anything which is repetitive.
You can use the quick action to easily program a custom zero point. I’ve used this to save multiple work offsets for vices on modular fixture plates.
The Run screen on the beta versions of Carbide Motion has an option for setting up. Just such macros. Also, if you want it to go to a specific point when it’s done, you’d have to program that into the gcode of that file.
