As requested on support…
If you have a design which is cutting beyond the edge of the stock:
It may be fixed by:
- drawing circles of the correct size:
Aligning with the geometry:
duping and repeating:
Drawing in geometry which defines the edge of the stock:
Selecting everything:
Using Trim Vectors to delete everything which is not needed:
until one arrives at:
which may be selected:
and then the Join Vectors command used to close the geometry:
and the new geometry re-assigned to the toolpath if need be so that cuts do not extend past the stock further than is necessary:
Repeat for all other geometry which extends beyond the stock.
