Tool geometries which undercut are not supported in Carbide Create.
The usual approach is to make a placeholder tool, work up reasonable feeds and speeds, cut the central channel clear w/ a square tool, then use a No Offset Contour to make the cut where one wants, but note that it will be necessary to double back.
Alternately, if it’s a short distance a Keyhold toolpath may be used.
