Hi,
I know the best way is to have the stl cut and sliced in the correct shape before importing into Meshcam, however, there must be a way to position the stl object within the stock via Meshcam.
Lets say i import a sphere into Meshcam that has a radius of 4 inches, but my stock is only 2 inches thick. I then want to position the sphere in a way, that Meshcam only carves the top half of the sphere. I will need to position the sphere (maybe via the stock window?) so that the bottom of the sphere basically sticks out underneath the stock.
How would i do that?
Thanks!
Oliver
