Hello, I am curious as to how to zero my X and Y coordinates when I am cutting or carving a work piece that is as long or as wide as the bed on my shapeoko 5 pro 4x4. It seems that I can"t use the bitzero V2 on the corner of the work piece since the probing hub on the bitzero would then be extending past the wasteboard and beyond the reach of the spindle. Is there another process or approach that I am missing? Any insight would be appreciated!
In short: you can’t. The machine needs to move past the left and front edges of the stock material in to use Bitzero to set the working zero of the X and Y axes. If you’re using the full width and length of the bed, there’s nowhere for it to go.
Edit: Technically there’s 16.8mm of extra space on both the X and Y axis, which is enough to use the Bitzero if you’re using something that’s exactly 48x48 inches. Workholding would be the real challenge.
That said, you can still use it to probe the Z axis, since that can be done anywhere.
When I have a large piece of material where I can’t use my bitzero I setup the file for center zero and use the paper method.
I use center of material for most of my projects. I just draw a line from opposite edges and get an X marked. I often use painters tape so I dont mark up my material. Plus a pencil can leave a dent if you press too hard and have to sand that out. I jog with a vee bit to find the X and Y center. The Z can use the BitZero for Z only or as @Jeffish said use the paper method. A lot of people use the lower left corner but that is limiting for some projects.
If your project is at the edges of your spoilboard I have used hot glue to hold a project down when I could not get clamps on it. After machining just put some denatured aclohol on the hot glue and wait a few minutes and it will peel off. If it does want to come off easily just put more aclohol on with an acid brush and let it sit about 5 minutes.
I started a project last night that was very tall and on the edge of my spoilboard (SO3 XXL) so I fabricated a little clamp. I drilled a hole for a hold down bolt and then put a threaded insert in to hold the clamp. Because the sides of the project were slanted I was afraid the project would move during machining. I have a threaded spoilboard with 1/4-20 tee nuts.
I use these tags to find corners and zero there or edges. The camera is mounted the opposite side (to the inside of my material so it “reaches” the edge)
is there another process or approach
For various reasons I zero manually not with a probe… Then again I preview all my gcode manually. Call me old fashioned ![]()
To manually Zero off top of material with a rectangular sheet when a probe will not suffice
- load a V-Bit cutter with a small flat. I use a 30deg with .010" flat tip. 60 or 90 will work fine
- Jog the bit to the corner of the sheet which corresponds to the origin of the drawing. This is probably front left if following the default process.
- When the point of the V is at the corner and touching the top, in CM Jog screen, press Set Zero, then press Zero All. Bit will make the trip over to BitSetter to measure.
Also be aware when machining to the edge of a sheet, such as surfacing, to allow a buffer for out of square sheets. Everything I buy up to 2’ x 4’ is as often up to 3/8" under or over but not equally all around. Corners are then more or less than true 90 degrees. When positioning them on the table, I sometimes skew slightly to account for this.
