My z won’t pause and raise up?
Which 517? Carbide Create or Motion?
Please contact us at support@carbide3d.com
We don’t keep older versions — what specifically are you having difficulty with?
Let us know step-by-step:
- what you did
- what you expected
- what actually happened
we will do our best to sort this out.
- When I first bought the machine I could pause the machine and the z would go up.
- Only carbide create file will the machine pause and the Z goes up away from material.
- Another file I use it will not pause and retract up
Which post-processor are you using? It should be Carbide 3D Shapeoko.
What is your safety/retract height set to?
