I’m learning very quickly that often the CNC discipline and the woodworking discipline are not always possessed by the same person I’m watching do a tutorial or how-to video.
My biggest pet peeve thus far… sealing wasteboards/ spoilboards/ baseplates. Here’s a few friendly tips about what you should and shouldn’t do…
DO NOT use Plywood over MDF, regardless of how each responds to humidity MDF is FAR more dimensionally stable and is generally flatter than even the highest grades of plywood after manufacturing.
There are different grades of MDF. LDF, MDF, and HDF (low, medium, high) Density are all colloquially known as “MDF”. There are also big differences in quality depending on who the manufacturer is. Call your local Woodcraft store to see if they stock some of the better quality panels.
DO NOT go to home depot and pick up your garden variety of urethane finish. There are massive differences in the quality of finishes. Nothing annoys me more than about someone wanting a flatter reference surface then using a finishing product that is not Self-Leveling. Many of these products are meant to be applied with multiple coats with sanding in-between coats. Master finishers can’t achieve perfectly flat results with them and neither will you. Instead…
Use a SEALER not a buildable finish. Something that will soak into the MDF and seal it is a better idea then a finish that sits on top. My recommendation is Smith’s Original Epoxy Sealer. Know in woodworking circles as “CEPS” https://amzn.to/37b8hJm. It’s not thick like the epoxy you’re thinking off, it can be applied with a foam brush, applicator pad, t-shirt, whatever really. Mix it well and you can’t screw it up. My XXL baseplate just took a soup-bowl amount so the pint size is plenty.
DON’T forget to do the edges! The end/edge grain of MDF is most susceptible to humidity apply a generous amount to get it sealed.
Make your life easy, do the edges first, then the backside, then the topside. Use something like this to get it all done at once! Painters Pyramids
#EndRant hope you find this helpful.
… Even still non-waterbased would be a better idea.
