I took a picture of my puppy and got the roughing done. Now I want to go back and do the finish. I set the zero and x, and y to the original settings of the roughing pass and only have the one finish toolpath enabled.
I also set the stock to leave at .3. Now when I simulate it starts and looks good but that bug jumps up and shuts it down.
876 is latest stable. 877 is beta.
Pretty sure updated some stuff recently on rendering? Or toolpath calculation, but it may have occurred prior to the one you have.
If you created both the roughing and finishing toolpaths in the original design nothing changes when you disable the roughing toolpath. The finishing pass should run as normal.
Not sure what you mean by the simulation shuts down due to a bug.
