How to use the Height, Width, and Thickness variables in a design
As requested on support…
First, set up your stock:
Then draw in geometry:
and fill in the appropriate variables:
Note that the variables will be instantiated as soon as one tabs into the next field or switches away from the application.
If need be, align or position as necessary:
Note that the usage of the dimension variables is not constrained, one can use Height for X and Width for Y if need be, and they may be mixed, so:
Using these values in a radius will require halving them:
With the desired geometry in place one may then assign toolpaths which use the t variable for Stock Thickness:
