As requested on support…
Given a Job Setup:
and Carbide Create file:
One would set up to cut it by…
Securing a suitable piece of stock on the machine:
Power up,
connect to,
and initialize the machine
If using a BitSetter, w/o a BitZero, load the first tool and allow it to be measured.
If using a BitZero, install a probing pin, and if using a BitSetter, allow it to be measured.
Go to the Jog window, acknowledging the warning window:
Jog to and then set the origin relative to the top left corner of the stock to match
Go to the Run tab and load the file:
verify that it matches the 3D preview:
Done
Start Job.
It should cut as expected, so as to match the G-code:
If it doesn’t, something is wrong with the setup, or the mechanics, or the electronics, or something else — let us know at support@carbide3d.com
