I’m just installing the HDZ and didn’t see anything in the blog instructions on how and where to attach the drag chain? A photo would help immensely
Drilled and tapped a couple of 5mm holes, printed a bracket.
Either be careful or use a drill stop to avoid going all the way through the backplate. Use a center punch to mark the holes so your bit doesn’t skitter all over that pretty blue anodizing
I love the linear guide.
Thanks. Not sure yet if it does much for me, need to cut a lot more parts.
I’m curious too. I just installed mine on Friday but I haven’t tested it yet. However, I don’t have it bolted to the stepper motor yet, lack of M5 threaded rod around here.
Just like this.
Excellent picture - thank you.
Picture is worth a 1000 words
