I was installing the tiling fence from the Cut Rocket library last night, and when I went to surface the front of the tiling fence as recommended, I zeroed the Z to the hybrid table and just toughed the bit to the tiling fence and ran it from the SW to the NW position. As it ran, I noticed that the hybrid table actually rises up 0.095", which kind or surprised me that it was so much.
So I was going to run the slab flattening file, but is there something I missed when setting my S5Pro 4x4 up (I found nothing in the manual related to this)? I realize I need to see what the difference in heights of the hybrid table are at the SE, C and SW positions. When I looked at the aluminum cross frame member that join the left and right sides, they are all sitting flush to the table I built. Any suggestions? Or do I just go for it and resurface?
