Having a very bad day carbide motion will not select more than one thing when i hold the shift keyβ:rage: anyone know how i can fix this tried typing with it an it worked perfectly normal???![]()
I assume you meant Carbide Create not Motion⦠try saving your file and closing it. Re-open it and see if the problem persists.
It is shift-click to add or remove an item from the current selection.
Drag up is promiscuous and adds anything which is within or partially within the drag-rectangle to the current selection.
Drag down is selective and only adds those elements which are fully within a selection.
If things arenβt working, reboot and check that no utility programs are running which modify any behaviours.
K looks you have to double click and hold to do this now
thanks for the help.
