I can literally hold my hand on the body of the router while it is surfacing while holding a metal chair and it will still cut out due to static. Not sure if there is a good solution here?
I havenāt had any issues when machining similar PVC, but got tons of cutouts (requiring SO3 reboot) when cutting Corian. I had to run the last ~2 min of the job multiple times to get it to complete.
Maybe you need a week off . I have to try to remedy this on my machine starting this week. Itās very frustrating when glitching at the frequency you mention. Can you use a smaller bit to get by until you can try to fix it?
I donāt do a lot of PVC surfacing⦠so its okay for me, but i bet its a great repeatable test to see if someone can come up with a be all end all solution to this issue.
I feel like you have probably checked this also⦠but Iām pretty sure it wonāt matter if youāre grounding the router while itās operating. The router is ostensibly already grounded via the 3rd conductor on itās electrical outlet. I forgot that the hand router doesnāt have the ground conductor.
Every time I have had an issue (and come to think of it⦠seems that it only happened when surfacing mdf with a 1" bit), it was because my vacuum hose was isolated from the router and/or its bracket.
During normal ops, the hose would sometimes flex during a rapid change in direction, causing the hose to tap against the router or bracket. If it had enough static at the time, thatās when it would happen due to the sudden transient. So I could either ensure that the vacuum hose stayed in contact, and allow the potential to escape through the router to its ground, or I could ensure that the hose never touched anything during operation. Of course, the second option means that it will be building a lot of static, and it still could find a way to discharge in an unpleasant way.
Anyway, that was my rigged solution, and it seemed to do the trick. Most folks recommend a more elegant solution like an anti-static hose and/or conductive wire wrapped around the hose, terminating at a solid grounding location. Another thing worth mentioning is that some people seem to have found at least a little success with plugging their cnc into an uninterruptible power supply, but I feel like that is more for the disconnects related to power transients from an unstable electrical supply.
Iām new, so this may be common knowledge. But I had disconnect issues with mine recently. I did some testing and narrowed it to only those times my dust collector was running. So I wrapped a bare copper wire around the DC hose and grounded the end nearest the collector to the building ground (which is also connected to the router ground, computer, S3 power supply, etc.). Iāve not had a single disconnect since. Iām following this topic because I plan to machine PVC soon. HTH.
Tested the continuity to ground of your Z assembly and X beam?
Used a conductive anti-static hose for dust collection (if present) and grounded the hose?
If youāre using a ātrim routerā these are generally double insulated, donāt have an earth wire and neither the outer shell nor the collet has any path to ground. When youāre generating all that friction with the big surfacing bit youāre basically got a big van de graaff generator running and youāll need some properly thought through paths to ground for all that charge that isnāt the stepper motors and Carbide controller board.
The human body is not a great conductor. To discharge the amount of static electricity youāre generating, you should have a copper wire run from the router body directly to the nearest ground. Use a power (house) ground, not any ground on the controller board. The bigger wire you use, the better. I assume you will want stranded wire so it can flex easily.
Out of curiosity, where do you live? Humidity can play a big factor in winter, and Iāve heard second hand of someone fixing their static issues by bringing a pot of boiling water into the shopā¦
@wmoy yeah its winter⦠20-30% and Iām sure thats a factor, but to clarify my issues are⦠no other issues in any other material other than surfacing bit on PVC. I used to get issues in surfacing my MDF waste-board but those are long and gone.
Iām familiar with most of the fixes discussed and Iāve implemented some but not all. But Iām betting this is the extreme test to see if youāve succeeded.
I donāt know which router heās got, but my Carbide router is double insulated and itās only got a 2 prong plug so thereās nothing grounded on the router
a few guesses
Drape some anti-static tinsel and run it to ground. (cheapest, easiest)
-or-
Place some ESD tape under the material and again, run to ground. (almost as cheap but not re-usable)
-or-
an Anti-static Ionizer (a bit pricey)
As to the router, new does not mean it came with a good set of brushes. I would check that first as it is available and no cost, inspect the brushes for even wear and good contact and clean the housings before re-installing.
If you can be careful, hold your hand close to the material while surfacing it, you can feel the static build up in your arm, (hairs will start to stand) and expect the strong static discharge when you do contact grounded objectsā¦dont use a finger tip, enough charge can split the fingernail, discharge it through the palm of your handā¦
Trying to diagnose a problem through chat is like calling a Doctor and saying, I Donāt feel good, fix meā¦the Dr. may say take a few tylenol and get some sleep, but that does nothing for the Dodge truck sitting on your footā¦
Would it be at all feasible to run a ground wire from a know-good ground to the PVC project? Run the ground to a clip and clip it to the pvc piece?
Just thinking outside the boxā¦
Bill
