I need help to add tool
Amana RC-2247 1-1/4 anyone can help me please to add it into carbide create library?
Thanks
The old (316) method isn’t compatible with the new (400 and later) method, and unfortunately custom tools from 316 are not directly imported into newer versions.
In the newer version in order to enter a custom tool it is necessary to create a new user library — tools may then be added to that by using the graphical interface.
See:
Note that since the move to curated values in 434, certain entries which were required are now hidden in the data since they are not needed.
This is helpful! Thank you very much.
