Increasing Rapids on 5 (5.1)
Is there a controller setting that can be modified to increase X and Y rapids? I thought I read this here somewhere that it can bump up from 200im to 250im or their metric equivalents but I can’t find it now.
It just feels like the machine is so very slow when I run a program like drilling a series of small holes spread out across a large area. It’s like 75% of the run time is moving between holes and only 25% is cutting them. I’m not trying to cut any faster. Thank you.
$110, $111 and $112 – [X,Y,Z] Max rate, mm/min
Thanks. They lost me at the first sentence. How does one connect to Grbl using the serial terminal?
I’ve seen those values in machine settings and I know how to use MDI. I just don’t know how to get into edit mode to change them.
You can use MDI. Make sure the log is open to see the responses.
$$ [list all variables]
$110=250
$111=250
$$ [List to verify]
Look at the retract height you are using, you may want to reduce the retract height and/or increase the speed of retract. It can make a large difference in time.
A change of 200 to 250 ipm is 25% time savings.
Oh gosh that was it. I didn’t have the log open. Thanks.
Can you tell I’m new at this part? :rofl:
Settings are all metric right? I see 500 for all 3 which must be cm.
I’m not in a rush I might start with 10% more and see how it goes.
thanks I do use .200" above material for rapids whenever possible for the reason you said. Does the $112 Z value control both up and down?
I read that increasing it could cause problems on the rapid plunges toward material because of the the spindles weight .
$112 controls all Z rapid motion, up & down. Plunges into material are usually G1 linear with the programmed plunge feedrate.
thanks I mistakenly looked at $120-122 first Made me think it was cm. All good now.
I set $110 and $111 to 6000mm/min. Working properly.
I noticed the change doesn’t affect jogging. Jogging at Fast speed still tops out at 5000mm/min or 196.3in/min. The log shows F5000.
Is this expected?
