Hi all,
I am creating single stroke fonts from Inkscape into CC as SVG. A problem I am encountering is that some letters and numbers are missing strokes.Im saving as a regular SVG
Has anyone else seen these issues?
Thanks
Eve
Hi all,
Thanks
Eve
Make sure you are converting your text objects to paths. Select the text objects, then select Path>>Object to Path (or Shift+Ctrl+C)
This does not solve ir I’m afraid
Carbide Create doesn’t seem to have support for open-ended paths, which any of these letterforms which do not have counters would be.
If you want to use these fonts directly, I’d suggest doing it w/in Inkscape using Gcodetools, or by using MakerCAM.
The big reason to use single stroke fonts is efficient routing of letterforms — the problem is, this efficiency results in a boring, unmodulated, mono-weight/width font. If you can find the time for it, it’s better to use a normal typeface and a V-bit to instead V-engrave the text — you’ll get a much better and more expressive typesetting.
If you must use these fonts in Inkscape, then it’s simply a matter of expanding the strokes to paths (which must be ~10% larger than the size of the bit which you will be pocketing them w/) and then combining everything together:
