CC623 is very glitchy for me, when I move objects around on the screen it leaves trails, it won’t copy/duplicate images, i find most of the CAD options don’t work as intended.
It worked well for me, but I’ve since moved on to the new beta:
https://carbide3d.com/carbidecreate/beta
If you have a repeatable difficulty in a current or beta version in an up-to-date OS version, please let us know, either here or at support@carbide3d.com and we’ll do our best to look into it.
Older versions of cc when you did ctrl c an object immediately appeared. Newer versions when ctrl c is used the object is copied to clipboard. So move curser where you want copied object and ctrl v and your object will appear. You can also ctrl d but I have not used that yet.
