Using CC and would like to lay multiple files on top of each other to envision how the final product will look. Is this possible with CC? For example say I’m making a topo map and each layer is a file. Can i put layers of the map on top of the layer below? Thanks for the helping me learn this software, very much appreciate it.
Using the Library | Import External File you can add a DXF or SVG file to your current .c2d file.
You can export the contents of an .c2d as an SVG, but you’ll lose the toolpaths.
