Would it be at all possible to use the V carve pathing as a way to draw a center line to follow with a V bit in the contour cutting section?
While yes, a V carving toolpath will cut along the center, no, if you want just a following of the path you probably wouldn’t want to use this if you have the option of optimal geometry because of the extra movements at ends and corners and so forth.
