I see a few on Cutrocket for other Shapeokos, but not the 5 4x4. I am looking to replace the MDF slats with HDPE, but it would be super helpful to have the exact measurements in a file to use as a starting point.
Here is a PDF of the Shapeoko Pro5 4x4 spoil-board slats. The width dimension is missing on the drawing and the CSK hole dimensions point to the incorrect features
, measuring mine the dimension is: 2.95"
https://my.carbide3d.com/pdf/CS-S5-MDF-REFERENCE.pdf
Shapeoko Pro5 4 x 4 Spoilboard.DXF (14.6 KB)
Shapeoko Pro5 4 x 4 Spoilboard.STL (1.1 MB)
NOTE: This .nc file is in MeshCAM. You will have to configure it to your machine.
Shapeoko Pro5 4 x 4 - .75 Thk Spoilboard MDF.nc (63.8 KB)
Thank you for these!
