I am carving a pretty extensive logo. The logo doesn’t have a solid outline. I would like to carve an outline slightly larger than the entire logo, I was going to try and do a contour of the 5 different sections, but it muddies up the area where the sections are close to each other, i.e. where the ax gets close to the cheek bone. I would rather outline around everything and not go in between the individual areas. Hope that makes sense. Here is the logo and the CC file. TIA
SKULL.c2d (1.1 MB)
Use the offset feature, outside direction,
and then come back and delete the extraneous inner parts ?
Perfect! Thank you! HAve a great day!
