Hey All,
I just installed CM 636 but now I keep getting this error:
I tried setting up the machine twice and used different CC files but each time I get the same result.
Could someone please help?
Many thanks,
Gunter
Hey All,
Many thanks,
Gunter
This is a warning as noted at:
https://carbide3d.com/blog/carbide-motion-bounds-checking/
Where is the origin set in file? Job Setup
How and where are you securing the stock and setting zero relative to it? Movements + Zeroing
What is the safety/retract height set to?
Are you using a BitSetter? What length of tool is being used to set zero?
Please try:
If you continue to have difficulties please upload your .c2d file and take a photo showing the stock secured on your machine and with the machine at the zero position or a specified offset from that position.
Thank you for your quick reply Will, I changed my zero and it all works great now!
Gunter
