Issue with Carbide Motion 6.18 and Shapeoko 3 XL
Hello,
I had created a bunch of gcode files before Christmas to make different hockey puck beer openers. Everything worked great and I ended up making about 30 of them.
About two weeks or so ago, I updated my software to Carbide Motion 6.18 and now all of a sudden I can’t cut anything correctly on the my machine. I set it up to run the same files I ran before the update and it’s like it can’t register Z-index after using the Betzero 2.0. Has anyone else experienced anything like this?
I currently have:
Shapeoko 3 XL
Bitzero 2.0
Bitsetter
I created all the gcode files from Carbide Create Pro 764.
Any help would be appreciated as I don’t want to waste anymore wood or have to get a new CNC.
Thanks,
Joe
Did you run the Setup New Machine wizard after you upgraded?
I didn’t the first time, it failed. I deleted the software off my machine, reinstalled and ran setup new machine wizard, same issue. Updated windows on my machine, removed the software again, restarted, and reinstalled. Then I checked the gcode in Carbide create, went to Edit → Select Post Processor, changed from Imp to Metric. Saved new gcode, ran it same result.
