Issue with PCB upgrade for the VFD Spindle Kit
VFD Spindle Upgrade for the SO3 XXL.
I had to order a new PCB with the 6 pin connector bitsetter connector to accept the plug from the VFD control box. I also had to order it with the new enclosure that has the port for the connector.
I did not receive any screws to mount the PCB in the enclosure so I tried to use the socket head cap screws from my original PCB. Surprise!!! they are too big for the standoffs mounted in the enclosure so I cannot mount the new PCB into the enclosure.
Has anyone else attempted this upgrade and had the same issue with the enclosure?
Are there any specs for the size of the cap screw that will fit the enclosure standoffs for the PCB board?
Does anyone know if the standoffs in the new enclosure can be removed and replaced?
Kind Regards,
Bryan M.
I found some screws that fit from my local Ace Hardware.
Standard 4 x 40 x 3/8"
Thanks,
Bryan M.
