Hi all!
I’ve been using my Pro XXL for about 3 weeks and I’ve just recently received 60 and 90 degree v-bits. However, when I try to use them in Fusion 360, no matter what I try I get the following error:
I’m new to using v-bits so I’m not sure where to start trouble shooting, but the videos I’ve watched haven’t helped all that much. I’ve followed them and still result in an error.
If anyone has come across this issue, hopefully they might be able to help.
Thank you!
I used the Engrave toolpath and I tried the #301 and #302 v bits straight from Carbide3d, I get the same error for both.
I’ve also tried multiple methods of selection, face, edge, sketch-line, and text. None seem to work.
Nope, No C3D v bits. But what I ran across is that it seems that Fusion looks at the tool category to decide if it can generate a toolpath with a tool from that category. What I did, and commonly do, is just create, or modify a tool in the category that will work for what I need. In your case, I assume you’ve tried something from the “engrave/chamfer mill” category. I would open up something from the “tapered endmill” cateogry, and adjust the settings to what matched the other tool I tried to use. After all, a screwdriver can be more than just a screwdriver. Here’s a video I found that may help you out. https://youtu.be/IguCUtUowm8
