Made this sign for my bar last night. Finished size is 20" x 16". Took nearly 8 hours to carve. Once the cutting was finished, I went over the surface with a propane torch to give it a unique finish.
That’s beautiful work. May I ask where you got the file?
What software did you use?
(Looks great, BTW.)
File was an STL from Thingiverse and a friend created the gcode for me using Vectric Aspire.
I know this is an old thread but would anyone happen to have a gcode for this. I am struggling to get it to cut correctly using Fusion 360 and Mach3. thankyou.
You should be able to make G-Code for that using MeshCAM:
or any other 3D CAM tool.
If you have Carbide Create Pro you could use a 3rd party utility to make a pixel depth map of the SVG and cut that.
This topic was automatically closed after 25 hours. New replies are no longer allowed.
