Job Pauses when Running Job
Interesting issue. Got a new computer a few months ago and this is the first time i’ve used it with my Shapeoko Pro. The machine seemed to initialize fine but when i run the job the machine would pause for a few seconds, then continue, then pause, then continue and so on. But it would continue running the job. I finally got disconnected. I had the Shapeoko Pro plugged into a non powered adapter/splitter on the USB port. When i removed the splitter and plugged directly into the USB port on the computer that seems to have corrected the issue. This same setup worked fine on my old computer. I’ll update if this reoccurs. But looks like for now its fixed.
Purchased a powered USB Port Expander and now everything seems to be working as expected. Can plug my ShapeOKO Pro, Jogging Device, and Laser into the expander and everything communicates as expected.
