Quick question. I often prefer manual flattening passes for certain pieces. Running Bitrunner V2 Deluxe, Shapeoko 4 XXL. Is there a way to perform this operation with Bitrunner enabled? Using the jog function with the router active, Bitrunner shut the router off. Expected behavior or no?
I believe jogging with the spindle on was disabled out of safety considerations.
I assumed as much. I’m generally running a beta of CM, and wasn’t certain if that was intended behavior or not.
