Hi, is there a way to join two ends of a vector that isn’t closed. When I used the trace function, it made a piece part of a node that should have been separate. I know I can use the Cut function to remove it, but I can’t figure out how to close off the rest of the vector so I have one continuous shape. I know Boolean removals are an option, but would prefer not to use them as it always creates more nodes than I would like when the shape is rounded.
Thanks!
I would like to separate the smaller piece from the larger one
After cutting them, these are two pieces. I would like to complete each vector, separately.
