Hello. Is anyone using Joint Cam? I was hoping someone has the settings. I have the S5pro mounted gantry forward with a vertical mounting board.
Thanks in advance,
James
I’ve looked into it, and have done a fair bit of vertical joinery such as it wants:
https://cutrocket.com/p/5cb536396c281
but after getting it out of my system, I’ve found that other techniques, most notably full- or quarter-blind hidden box joints are preferable:
https://cutrocket.com/p/63781eaf9822f
https://cutrocket.com/p/622970cdb482a
https://cutrocket.com/p/67b86d0d17056
Advantages:
- only one setup per part, not 3 or more
- less chance of error
- greater flexibility for features such as the hidden hinge
If you have a set of dimensions for a box we can gladly walk you through setting it up.
