Just pulled the trigger Shapeoko XXL CNC Router Kit What spindle upgrade to consider?
VFD Parameters (Huanyang model) is the place you need to go… More than enough reading to keep you dangerous! The VFDs are mostly the same, you’ll need to tweak some settings for 220, and spindle specs- which you should be able to get.
