Please send the file you are cutting in to use at support@carbide3d.com and let us know the specifics of your electrical setup and we will try to look into this.
Usually, this is EMI, but the SO5 Pro was engineered to make this much less likely.
Not the file as it does cut. I am doing a second one agin now as we speak and no issues. Vfd is on it’s on 20Amp circuit and plugged into the wall directly and the workstation and controller for the Machine is plugged in through a surge protector and on its on 15 amp circuit. Nothing else hooked to these as I wanted to make sure I wasn’t going to overload the circuit.
Dust collector is on a totally different circuit as well. I built the shop last year with all in mind.
If you haven’t done so already, an antistatic dust hose for your extractor with the metal wire through the hose grounded can help in reducing static and thereby interference too.
I had the same quit in the middle of a file on my SO4XXL. After research, I placed my entire setup on an Uninterruptible Power Supply (UPS), which has saved me on a few local power outages. In addition, I ran a well grounded copper wire from inside the dust hose around the outside of the hose to ground. No premature quitting problems since.
Running a test run for monograms on two stove top covers. So far I have not been able to complete the test due to the machine “Shapeoko Pro XXL” has lost connection and stopped feeding and just running in one spot.
Not in the same spot, not even the same tool.
Never had this happed previously. Can someone guide me in the correct direction to stop this from happening? PLEASE?
How do the brushes cause the machine to disconnect but have the router continue to operate?
My garage is on a separate circuit than the refrigerator?
It’s getting colder here with minimal humidity.
All I know is, so far is it is running up to this point with no issues. Knock on wood, stick a horseshoe in my pocket, pull out my rabbit’s foot and currently looking for a leprechaun.
Currently out of Lucky Charms.
Worn or damaged brushes don’t mate to the armature sufficiently. The larger and/or irregular gaps between the brushes and armature causes arcing and produces higher-levels of EMI.
Had this happen several times over the years, easy check would be to turn on router and look at top of router, any minor sparking wont shut off the router but will cause a disconnect. Which in my opinion is a little over sensitive however better to be safe than sorry. Also if the armature is damaged or bearings are starting to go it has the same effect. I ended up ordering armature replacements from ereplacementparts.com. as i could get 2 armatures for the price of a new router.
Figured it out. The wife had an extension cord plugged in to the outlet and had the fridge AND freezer we have in our garage. Ugggggggg. Took it all off of the circuit and the vfd and spindle are all by itself on a 20 amp circuit and working like a dream!
I find it odd that an EMI field from bad brushes is effecting controller connectivity. I also operate a CNC Plasma with an 85A power supply, now that is an EMI field, yet I have never once lost controller connectivity. This leads me to believe there are some serious design flaws or corner cutting of the Sapeoko electronics.
