Keeping the 65mm vfd spindle's power connector from unscrewing?
After about an hour or two, the power connector at the top of 65mm vfd spindle on my shapeoko keeps unscrewing due to vibration. Has anyone else had this problem and maybe found a workaround?
When the power connector come completely unscrewed the shapeoko will drag the non-spining bit across the material on my machine. No amount of tightening makes a difference.
I have not experienced this yet. My 65mm spindle runs pretty smooth while cutting.
Short piece of heat shrink would work.
Perhaps a wrap or two of Teflon tape?
A small dab of hot glue?
I also had this happen 2 days ago. I was on the other side of the shop and heard the spindle stop spinning and run over to stop button before it broke something. It was unplugged and it has only been running for a couple of hours. I am checking it at the start of every time I start a new job for now to see if it loosens up again.
Yep, me too, I check the connection every tool change and that is about all I needed to do… But I’ve forgotten a few times and found the screw loose.
I’ll try hot glue, Teflon tape or maybe lock tight.
That is excessive. I’ve had C3D 65mm spindles on 2c machines, one for 2 years, one for over a year. Are you running a really out of balance tool? I’ve had that happen once. Maybe a small dab of blue Locktite?
Yes, happened with multiple replacement spindles with me though I caught it before the power was ever disconnected. I solved it with a thin and tight rubberband just above the coupler. Simple enough to remove if necessary.
That’s one of those pre-flight checks .
Clear table
Spindle on
Spindle nut
Sweepy clamp screws
Bearing grub screws
etc …
After tightening the cable connection i marked a line with a sharpie across both sides of the connection so i can quickly visually check if the connection has loosened
